Angular Dimensions will be deleted when a auxiliary line deleted
Thanks: 351 times Was thanked: 257 time(s) in 169 post(s)
Sometimes i create some auxiliary lines to create some Angular Dimensions. I deleted the layer with the auxiliary lines and all Angular Dimensions which was in a dimenions-layer, was also deleted.
Edit: Maybe this is a feature and no bug because of a relationship between the geometry and the dimensions.
Edited by user Wednesday, August 22, 2018 11:16:59 AM(UTC)
Originally Posted by: MPSchmied Sometimes i create some auxiliary lines to create some Angular Dimensions. I deleted the layer with the auxiliary lines and all Angular Dimensions which was in a dimenions-layer, was also deleted. Edit: Maybe this is a feature and no bug because of a relationship between the geometry and the dimensions.
Hi
the angular dimension depends on the line, the linear dimension depends on the points. removing the line removes the angular dimension.
Enjoy
Angular Dimensions will be deleted when a auxiliary line deleted.mp4.mp4
(742kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 8 times Was thanked: 77 time(s) in 39 post(s)
Quote: removing the line removes the angular dimension.
Don't delete the line, just hide it.
Originally Posted by: mitchb Quote: removing the line removes the angular dimension.
Hiding is really a good idea, i never used the hiding feature. I changed the color of the layer to a invisible color.
