able2able
#1 Posted : Friday, August 24, 2018 12:58:40 PM(UTC)
able2able
Cannot import large DWG or DXF.
Running Win10Pro on Intel i7-6600U with 16Gb Ram
Some of these files are 30<100 Mb large (too large to attach)so here is a link for DXF
https://www.dropbox.com/...gtm6/LAYOUT_001.dxf?dl=0
and another link DWG
https://www.dropbox.com/...nt%20Layout%201.dwg?dl=0
#2 Posted : Friday, August 24, 2018 3:37:29 PM(UTC)
The DWG took 45 min to get in Shark on my MacBook Pro.
It has almost 200k entities...
JL
#3 Posted : Friday, August 24, 2018 4:20:03 PM(UTC)
I had the same thing with some dxfs which were around 10 mb. Took ages to load and then slllllooooooowwwww to do anything with. You just can't load and run large files in this software, dxf, igs whatever.
#4 Posted : Friday, August 24, 2018 11:29:04 PM(UTC)
I saved as Shark and I'll try to attach...
#5 Posted : Friday, August 24, 2018 11:32:11 PM(UTC)
I'm sorry I can't attach the file (saved as Shark and Zipped).
Every time I get this server error :
Server Error in '/' Application.
Maximum request length exceeded.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Maximum request length exceeded.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): Maximum request length exceeded.]
System.Web.HttpRequest.GetEntireRawContent() +11989461
System.Web.HttpRequest.GetMultipartContent() +85
System.Web.HttpRequest.FillInFormCollection() +248
System.Web.HttpRequest.EnsureForm() +94
System.Web.HttpRequest.get_Form() +16
System.Web.HttpRequest.get_HasForm() +11984458
System.Web.UI.Page.GetCollectionBasedOnMethod(Boolean dontReturnNull) +106
System.Web.UI.Page.DeterminePostBackMode() +89
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +236
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2114.0
WORP3
#6 Posted : Saturday, August 25, 2018 5:43:57 AM(UTC)
WORP3
Netherlands
Not sure if this is the problem you are facing, but be aware that the latest ViaCad (Pro) version has an import problem/bug. I had the same when I updated to the latest version, couldn't even import an decent step file. Eventually after a downgrade, all worked fine again.
Original post of this problem: http://forum.punchcad.co...sts&t=9470#post36008
Edited by user Saturday, August 25, 2018 5:46:05 AM(UTC)  | Reason: Not specified
