#1 Posted : Tuesday, August 21, 2018 5:33:36 AM(UTC)
If using the In-Stream Zoom Commands for placing dimensions or drawing lines, the automatic auxiliary lines works no longer properly, you are not able to use the tangent-auxiliary lines or any auxiliary lines which go out from the start-point. Edit: When using Ctrl+F, the same problem. Then works only the X and Y auxiliary lines for every point and if the start point out of screen, is there no automatic auxiliary line which come from the start point.
Edited by user Tuesday, August 21, 2018 9:24:05 AM(UTC)  | Reason: Not specified
