mcaliebe
#1 Posted : Saturday, August 18, 2018 3:42:45 PM(UTC)
mcaliebe
Can anyone tell me if ViaCAD allows for text to be added in paper space? I want to print a drawing in isometric view, however I want my template and text boxes to remain in paper space. I can' seem to locate a menu command to switch between paper and model space.
#2 Posted : Saturday, August 18, 2018 3:53:08 PM(UTC)
Hello
ViaCAD does not use paper space. It uses draw views. You can create draw views and add text and dimesnions.
#3 Posted : Sunday, August 19, 2018 4:38:40 AM(UTC)
better use a model to sheet and modifying the draw views of the "model to sheet". And Draw views works only when the 3d space view at Top View. "Model to sheet" make this automatically and isolate the layers. But for optimal using the Model to sheet you need to0 change the template files. With the original templates it change the Page Layout Scale, you need to setup the page layout scale back to 1.
