Set origin (Not implemented?)
Thanks: 17 times Was thanked: 3 time(s) in 2 post(s)
For some reason when I try to use the workplane->Set Origin function i'm getting an "Sorry this option is not implemented" message. Is this correct? Is there an other way to reset the global origin beside moving everything? Hopefully it's just a dumb question and resetting the origin is just so easy i'm looking over it.
Thanks: 190 times Was thanked: 163 time(s) in 112 post(s)
Seems to work in SharkCad Pro PC 1371.
(66kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Originally Posted by: L. Banasky Seems to work in SharkCad Pro PC 1371. Larry
Mmm I think I got the working of this function wrong, I thought it was the global origin, but it seems only the origin of the workplane. Strangely enough the function seems to work now instead of getting a sorry message ?!?!!?
I just moved everything in the design so the global origin is where it should be but isn't it possible to just assign the global origin to a new snap point?
