WORP3
#1 Posted : Thursday, August 16, 2018 11:46:57 AM(UTC)
WORP3
Netherlands
For some reason when I try to use the workplane->Set Origin function i'm getting an "Sorry this option is not implemented" message. Is this correct?
Is there an other way to reset the global origin beside moving everything?
Hopefully it's just a dumb question and resetting the origin is just so easy i'm looking over it.
L. Banasky
#2 Posted : Thursday, August 16, 2018 12:15:43 PM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
Seems to work in SharkCad Pro PC 1371.
WORP3 on 8/16/2018(UTC)
WORP3
#3 Posted : Thursday, August 16, 2018 12:47:39 PM(UTC)
WORP3
Netherlands
Mmm I think I got the working of this function wrong, I thought it was the global origin, but it seems only the origin of the workplane. Strangely enough the function seems to work now instead of getting a sorry message ?!?!!?
I just moved everything in the design so the global origin is where it should be but isn't it possible to just assign the global origin to a new snap point?
