Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
If there's not already a fast one-click way to do this, could we pls have a Right-Click option on a Layer Name that Duplicates Layer? I guess you could copy/paste but that's not fun..
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Perhaps a little solution: Menue Edit > Select All; change layer from Layer 1 to e.g. Layer 4. Layer 1 is now empty, Layer 4 is active. If needed refresh Select All, Menue Edit > Copy; Menue Edit > Paste, this will fit in the copied objects to Layer 1, perhaps both layers are visible now on the screen, but they are positioned in different layers 1 and 4. Hide Layer 4 in the Concept Explorer and work in Layer 1. Hope it helps, for me it is not a pain. H.
Originally Posted by: flatpack If there's not already a fast one-click way to do this, could we pls have a Right-Click option on a Layer Name that Duplicates Layer? I guess you could copy/paste but that's not fun..
I'm doing copy and paste between layers 10 times a day...
Yes, I would like that the layer duplicate too.
Like in Excel, I can duplicate a sheet by moving the tab with Option key pressed.
It keeps all the "links".
JL
Edited by user Sunday, August 12, 2018 1:31:55 AM(UTC)
I will pass this feature request onto Tim.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
