Andrew Gray
#1 Posted : Thursday, July 19, 2018 2:21:33 AM(UTC)
Andrew Gray
Hi All
Here is a strange thing, see attached design
If I select the whole part and use the gripper to rotate, only the "yellow" plates rotate
now if I use the rotate tool and select the whole part, it will rotate but the hole in the blue part just screwed up
have a look and see if you know why it does this, maybe a bug ??
Detail 1.vc3 (79kb) downloaded 3 time(s).
BillB
#2 Posted : Thursday, July 19, 2018 3:11:47 AM(UTC)
BillB
It is because you have a hole that is linked to a point. Hiding the point and selecting all allows the gripper to work as intended
Edited by user Thursday, July 19, 2018 3:16:43 AM(UTC)  | Reason: Not specified
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
