#1 Posted : Thursday, July 5, 2018 5:10:37 AM(UTC)
Was thanked: 260 time(s) in 171 post(s)
I created a glass and want make a high res image, but the glass is no more transparent after rendering with the photo render palette.
#2 Posted : Thursday, July 5, 2018 12:18:57 PM(UTC)
The GlassModel example file has some example settings for transparent glass.
#3 Posted : Saturday, July 7, 2018 2:27:03 AM(UTC)
I opened this glassmodel example which i found in program files folder, and this transparency made i already by myself, after high res rendering is it no longer transparent, please watch it on the attached image.
