WORP3
#1 Posted : Wednesday, July 4, 2018 2:46:19 AM(UTC)
WORP3
Netherlands
I've noticed that for some reason the file size of my viacad pro design just doubled in size while I only added some simple boxes. File size was around 32.7MB after reading this design and adding some simple things and reshuffled some parts, I saved again which takes a long time. Eventually it was ready saving but I've noticed that the filesize almost doubled to 64MB which was to say at least not what I've expected.
Is there a way to reduce the file size again?
WORP3
#2 Posted : Wednesday, July 4, 2018 3:24:52 AM(UTC)
WORP3
Netherlands
Looking to all the menu options I did found a compact option which reduces the file somewhat to around 50MB still to large for what's in there.
Saving takes minutes while in the meantime windows tells me that the program isn't responding.
I'm using a Windows 10 x64 quad core i7 2.9GHz 16GB ram PC with internal SSD, ViaCad uses around 40MByte of memory after startup, 1.2GByte after loading design and up to 3GByte after working a bit with the design.
Edited by user Wednesday, July 4, 2018 3:26:05 AM(UTC)  | Reason: Not specified
posh.de
#3 Posted : Wednesday, July 4, 2018 4:39:53 AM(UTC)
posh.de
switch on all layers and unhide everything for checking the model content.
You may want check to import the file into a new, empty document and save then (to another file of course). Alternatively a copy&paste might do something similar maybe by losing structural information.
thanks 2 users thanked posh.de for this useful post.
GARLIC on 7/4/2018(UTC), WORP3 on 7/4/2018(UTC)
#4 Posted : Wednesday, July 4, 2018 10:59:16 AM(UTC)
Was thanked: 180 time(s) in 127 post(s)
Maybe u can also using the option "clear undo on save". Thse idea with the new file is also good,i made this several times.
WORP3
#5 Posted : Wednesday, July 4, 2018 3:56:25 PM(UTC)
WORP3
Netherlands
Thanks for the input guys.
Didn't know that there was such a "clear undo on save", will definitely look for that.
Splitting up the design or reduce the imported step file to more block like items will definitely help but in my opinion this should't be necessary for such a design. Working with this file is just fine, I wonder why it's taking sooo long to save that thing, even with the doubling of the output file, it's only 30 to 60 MByte which shouldn't take up minutes to save. Minutes in more like five+ or so.
posh.de
#6 Posted : Friday, July 6, 2018 5:39:25 AM(UTC)
posh.de
try if disabling "File > Preferences... > Filing > Save Preview Image" avoids the lagging during the save process of the document.
thanks 1 user thanked posh.de for this useful post.
WORP3 on 7/8/2018(UTC)
WORP3
#7 Posted : Sunday, July 8, 2018 8:49:15 AM(UTC)
WORP3
Netherlands
Thanks for pointing me to this setting menu. Although the time during save didn't alter but I could configure there that the undo is discarded during save. Nevertheless saving is very slow.
WORP3
#8 Posted : Saturday, July 21, 2018 6:53:23 AM(UTC)
WORP3
Netherlands
I've tried all settings and although the filesize reduced a bit, it keeps very slow. Simplifying the models imported reduces the filesize to around half (~22MByte) but it was still slow.
In the end the only thing that worked was just the create an empty document and copy all of the design from my original file into the new empty one and the file size dropped to almost 4MByte and saving was as normal again. Probably something was corrupt inside that slow file which got the saving process stuck on....
Nevertheless thanks for the replies and input.
#9 Posted : Saturday, July 21, 2018 2:14:54 PM(UTC)
I had the same thing building an assembly in Shark with the reference manager. I added and removed parts and the file stayed pretty bit, with seemingly loads of things on a layer, I started a new file did it again and the file was tiny. Straaaaaaannnnnggggeeeeee.
WORP3
#10 Posted : Saturday, July 21, 2018 2:32:19 PM(UTC)
WORP3
Netherlands
Indeed it is strange, just made a new file selected everything of the old en copied it to the new and it saved like normal again. Before that it took minutes to get the saving done which was also strange as in the end it was only just over 20MBytes..
But glad that it's gone, almost don't wanted to save again :)
