M65
#1 Posted : Sunday, July 1, 2018 4:54:04 PM(UTC)
M65
Question from a new user ViaCAD v8.
What click-option of ViaCAD v8 do?
To erase diagonal lines in cubes and zig-zag lines in the cylinders? Diagonal lines how "erase"?
(French)
"Bonjour, me prénommant Michel, je suis un nouveau utilisateur de ViaCAD 2D/3D v8 pour PC. Des milliers de questions! Me limitant, j'ai une apparition de lignes diagonales sur les quadrilatères et les surfaces courbes de cylindres. Comment enlever cette fonction automatique qui traces ces diagonales? Merci. Note: Je ne suis pas un habitué des forums."
M65
murray
#2 Posted : Sunday, July 1, 2018 5:49:23 PM(UTC)
murray
From your description, you're trying to edit imported mesh objects as if it's a graphical program. The simplest treatment would be to create native objects in ViaCAD, which are not mesh objects. If you're unfamiliar with CAD programs and you're serious about learning to use them, there is a lot to learn.
M65
#3 Posted : Sunday, July 1, 2018 7:02:19 PM(UTC)
M65
See the "problem".
http://zupimages.net/viewer.php?id=18/27/bhpf.png
How "erase" the diagonals lines?
÷ñÒ1116473400êÖ18õæ÷]How erase diagonal lines?
(French)
Je ne sait pas si l'image va être téléchargée. Il s'agit d'enlever les lignes diagonales blanches sur le cylindre. Comment faire?
Merci.
#4 Posted : Monday, July 2, 2018 2:58:33 AM(UTC)
maybe this is only possible with shark cad pro and subdivision to nurbs.
