Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Are subdivision objects only visible in Shaded view? I want to see them in wireframe. What am I doing wrong?
Thanks: 46 times Was thanked: 298 time(s) in 203 post(s)
If you select the bit, and go to inspector and type in a value for U and V, it should show up lines as a grid on the subd part so you can see it?
Originally Posted by: UGMENTALCASE If you select the bit, and go to inspector and type in a value for U and V, it should show up lines as a grid on the subd part so you can see it?
Ok thanks but I tried this and can't seem to locate a field for its U and V.
I've attached three files to show what it looks like:
1. Selected Shaded Mode (visible)
2. Selected Wireframe (visible)
3. DE-selected Wireframe (not visible)
Where should I be looking please?
Thank you.
(77kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Off the top of my head, click on the display tab next to where you are, and I think it's in there
Maybe the color of the edges match the background color?
(189kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Sorry, no I am still unable to find the U and V. I am using VC Pro 10. Could it be somewhere else?
*Edit: didn't see Digitalphasers answer until after I posted this. Its fixed now. Thanks both.
Edited by user Thursday, June 28, 2018 8:42:16 AM(UTC)
Originally Posted by: digitalphaser Maybe the color of the edges match the background color?
Yes this is it! THank you.
