Anyone else see an issue with the BOM in an assembly?
Attached are two images. Assembly built using the reference manager, nice feature. You can see the part in it's own window measures correctly, the part in the GA windows is way off, in all instances?!?!?
(63kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Reported as a bug, also doesn't bring in the part properties, material etc. Nor can you re add them in that environment
Edited by user Friday, June 15, 2018 5:48:22 AM(UTC)
