Kartoffel
#1 Posted : Tuesday, May 29, 2018 8:20:14 AM(UTC)
Kartoffel
Hello,
after installing the last update 1359 at the end of march, I don't have used ViaCad a lot (if any). Today, I startet ViaCad, and I get the Registration form. I filled out the form and then got the message, that the maximum number of allowed activates has been reached. I use the program only on one Computer (Win10)?
So, what is going on here???
A little bit frustrated
Markus
#2 Posted : Tuesday, May 29, 2018 8:43:16 AM(UTC)
Was thanked: 76 time(s) in 74 post(s)
Markus
Please open a support ticket
http://support.encore.co...frm.aspx?product_id=3871
Windows 10, Win 7
Andrew Gray
#3 Posted : Wednesday, May 30, 2018 2:05:20 AM(UTC)
Andrew Gray
I had the same issue a couple of weeks ago I opened a support ticket and they fix the problem with in half an hour
Todd Quinlan
#4 Posted : Friday, June 01, 2018 8:14:25 AM(UTC)
Todd Quinlan
It seems that updates to the operating systems may be changing the computers ID number. The program no longer recognizes the computer its installed on and thus kicks out the registration. As mentioned above, please just submit a support ticket to me using the link provided, include your serial key and I will reset it for you.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
thanks 1 user thanked Todd Quinlan for this useful post.
WORP3 on 7/9/2018(UTC)
eolfan
#5 Posted : Sunday, July 08, 2018 11:06:27 AM(UTC)
eolfan
I have exactly the same problem With my VIACAD 10 pro-1359 version / W10 OS and it's been two weeks since I reported it to the technical support but still not fixed.
Michel
(9 years Viacad user)
#6 Posted : Sunday, July 08, 2018 11:10:12 AM(UTC)
Please try reregistering the program and if that doesn't work contact Todd
[email protected]
Windows 10, Win 7
eolfan
#7 Posted : Sunday, July 08, 2018 11:46:48 AM(UTC)
eolfan
Thanks Jason, I've already done that two times after an OS update but this time I probably entered a wrong key and reached the maximum activates number allowed...
Nobody's perfect :-(( , but neither the registration system nor the Operating System should cause this.
#8 Posted : Sunday, July 08, 2018 12:18:42 PM(UTC)
One thing that causes issues is the browers auto complete feature the form gets updated with wrong info when it's finally submitted.
Windows 10, Win 7
WORP3
#9 Posted : Monday, July 09, 2018 9:31:32 AM(UTC)
WORP3
Netherlands
Good to read that I wasn't the only one. Didn't used viacad pro for a while and when I did need it for another project it wasn't registered again. When trying to register there seems to many registrations. I didn't changed anything causing this, eventually I needed to contact my seller to give me a new registration code.
Luckily for some reason I still had around 15 days of trial left so at least I could start on my new project and didn't lose to much time.
Todd Quinlan
#10 Posted : Thursday, July 12, 2018 3:53:38 PM(UTC)
Todd Quinlan
Michel
The registration system uses the computers ID number to identify the computer its installed on. Many of the latest updates to the Operating systems are changing that identification number of the computer and thus kicking out the registration.
I am sorry for your trouble, please email your serial key to me at [email protected] and I can reset your codes for your.
Todd Q
eolfan
#11 Posted : Thursday, July 12, 2018 4:32:23 PM(UTC)
eolfan
Well Todd,
I don't know how the maximum number of activates trial is reset but this time, after a few days I tried to register again successfully. To avoid errors on my registration key number I saved it as a *txt file and it worked fine.
Michel
