2D Drafting
Detail View - Move the letter
Thanks: 46 times Was thanked: 303 time(s) in 205 post(s)
Morning all, Looking at a way once a detail view is created, it seems to put the letter at the bottom of the circle at all times, how on earth do you move it? I'm finding it's not the most convenient place to have it.... Cheers
Thanks: 141 times Was thanked: 141 time(s) in 100 post(s)
Good morning, Right click in the view- Properties- uncheck Draw name box, use Text to put in new name, and you can place anywhere. Larry
Hi Larry, Does this work with the letter it puts under the circle which you draw around the bit you want to make bigger? Cheers
Should work, use Deep Select.
(33kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
2D Drafting
