What's wrong with the undo when used on grouped items?
Hi, this is irritating, I've got a load of lettering which I'm adjusting to fit in a gap. Basically I'm 3D printing it and at the moment it's too small, so need to step it up, have a look, and adjust further if need be. So you scale it up, realise it's no good, hit undo and only half of it moves back? The bits that don't move back are polylines I think, and the bits that do move back are where I have repaired the edge a little.
Please help
Cheers
undo scale doesn't work.mp4
(1,767kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
UG I would convert the letters to all arcs and then do scaling. The arc from curve tool is at end of the arcs tool bar Regards Jason
Is it possible to post or private email me the grouped items before scale? Tim
Interesting! If you drag the yellow scale box, the undo works fine. If you select the yellow scale box, edit scale, then undo they don't jump back. How do I attach a file that is 5mb? Every time I do it, it throws up an error?
Cheers
Edited by user Friday, May 11, 2018 12:54:19 AM(UTC)
for tim.slt
(44kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
