Jolyon
#1 Posted : Sunday, February 04, 2018 12:41:43 PM(UTC)
Jolyon
Extend Surface tool - editing immediately post-op does not work
ie. if it draws your 'surface extend' at the default extend length and you then type in a different number - it will not update
You have to delete and do it again with, supplying the length pre-op
There is also no entry in the History tree - why would that be ?
Not a biggie - but it's inconsistent !
Jol
thanks 1 user thanked Jolyon for this useful post.
GARLIC on 2/4/2018(UTC)
Jolyon
#2 Posted : Friday, May 04, 2018 4:18:23 AM(UTC)
Jolyon
Hello
Love to move this on ... it's an easy one !?
1.) If I 'extend surface' by say 10mm, then type 20 into the topbar ... nothing changes
.... also ...
2.) There is also NO Data tab in the Inspector for this tool
thus, once extended, there is no way to edit your extend ... other than undoing and redoing it !
Jol
PS. one thing I really love about this tool is if I click once in the middle of a surface - it extends in all directions ... fast and ever useful !
Todd Quinlan
#3 Posted : Friday, May 04, 2018 11:42:47 AM(UTC)
Todd Quinlan
Hi Jol,
Repeats here as well on both issues. I will report it to Tim and we will work toward a fix. Thank you For reporting this.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
