Art Smith
#1 Posted : Sunday, April 29, 2018 10:25:53 PM(UTC)
Art Smith
the "Loft Surface" tool seems a little too picky; see attached collage (SharkCAD Pro 1369)
Art
artesmith@earthlink.net
loft surface tool curiosity.jpg (52kb) downloaded 4 time(s).
Art Smith
#2 Posted : Thursday, May 3, 2018 6:07:46 PM(UTC)
Art Smith
has anyone been able to confirm either or both of the situations shown?? if I have a setting wrong, it needs to get fixed pronto because not being able to do any surface work with the radiused rectangles is a serious pain!!
Art
digitalphaser
#3 Posted : Friday, May 4, 2018 1:54:13 AM(UTC)
digitalphaser
Art
:) You're right. Loft does not work correctly with a set of curves. Loft does not work with groups. Ruled surface works well with groups.
Jolyon
#4 Posted : Friday, May 4, 2018 2:59:23 AM(UTC)
Jolyon
All the tools need auditing for :
1.) qualifying inputs
2.) useful tool rules & prompts
3.) constructive error messaging
One of the reasons Shark is hard to use is that the above are inconsistent
murray
#5 Posted : Friday, May 4, 2018 6:29:08 AM(UTC)
murray
Skin surface does work... I don't agree that Shark's hard to use, in absolute or relative terms.
Edited by user Friday, May 4, 2018 6:41:55 AM(UTC)  | Reason: Not specified
Jolyon
#6 Posted : Friday, May 4, 2018 6:45:50 AM(UTC)
Jolyon
Yes, it's easy to navigate once you know where the potholes are !
rockyroad_us
#7 Posted : Friday, May 4, 2018 8:05:19 AM(UTC)
rockyroad_us
It would seem it is a pothole with the loft surface tool but this tool as far as have known it for years is supposed to work with surface edges and non-closed profiles especially since that command has the bulge aspect to it. I suppose you can bulge it to zero from the 1 setting. But to me production and less keystrokes is a factor so I rely on the ruled and skin surface commands.
When closed profiles, just use the ruled surface or skin surface that one works for both non-closed and open profiles as well on the diagonal round.
Edited by user Friday, May 4, 2018 8:07:34 AM(UTC)  | Reason: Not specified
Guest (5)
