Surface Modeling
"Loft Surface" tool curiosity.....
                the "Loft Surface" tool seems a little too picky;  see attached collage  (SharkCAD Pro 1369)
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(52kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
                has anyone been able to confirm either or both of the situations shown??  if I have a setting wrong,  it needs to get fixed pronto because not being able to do any surface work with the radiused rectangles is a serious pain!!
Art
                Originally Posted by: Art Smith  has anyone been able to confirm either or both of the situations shown??  if I have a setting wrong,  it needs to get fixed pronto because not being able to do any surface work with the radiused rectangles is a serious pain!!
Art
artesmith@earthlink.net :) You're right. Loft
does not work correctly  with a set of curves. Loft
does not work  with groups. Ruled surface works well with groups.
                All the tools need auditing for : 1.) qualifying inputs 2.) useful tool rules & prompts 3.) constructive error messaging One of the reasons Shark is hard to use is that the above are inconsistent
                Skin surface does work... I don't agree that Shark's hard to use, in absolute or relative terms.
Edited by user  Friday, May 4, 2018 6:41:55 AM(UTC)
 | Reason: Not specified
                Yes, it's easy to navigate once you know where the potholes are !
                Originally Posted by: Jolyon  Yes, it's easy to navigate once you know where the potholes are !
It would seem it is a pothole with the loft surface tool but this tool as far as have known it for years is supposed to work with surface edges and non-closed profiles especially since that command has the bulge aspect to it.  I suppose you can bulge it to zero from the 1 setting.  But to me production and less keystrokes is a factor so I rely on the ruled and skin surface commands.
When closed profiles, just use the ruled surface or skin surface that one works for both non-closed and open profiles as well on the diagonal round.
Edited by user  Friday, May 4, 2018 8:07:34 AM(UTC)
Surface Modeling
