I'm trying make a solid object from faces I made. What tool do I need make this happen. I'm trying figure this out few a days now. Design started as some line and arcs Then made the faces. Now I like that faces to make the solid I need to work with. I be greetful for some help or a tutrial on the tool in question. 2/3d edition only
Stitch tool to stitch surfaces into a solid (it would need to be 'watertight') Post your project - if you can - then somebody can easily help you Jol
Originally Posted by: Zombie101 I'm trying make a solid object from faces I made. What tool do I need make this happen. I'm trying figure this out few a days now. Design started as some line and arcs Then made the faces. Now I like that faces to make the solid I need to work with. I be greetful for some help or a tutrial on the tool in question. 2/3d edition only
Maybe useful. Enjoy.
