2D Drafting
Line "Arrows" misaligned when printing drawing
for some reason, when printing a drawing, some although most line start/end "arrows" are slightly off the line end point which looks weird.
In the drawing view the alignment seems correct.
Any thoughts on this?
Regards.
hatch attached the following image(s):
(299kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
Hello hatch Can you post a picture or smaple file? Did you print to paper or to a file? Was the drawing scaled to fit a specific paper size? What version 9,10 and what build ? Regards Jason
Hi Jason,
The PNG image is now attached to the original post.
Build and version: 10.0.5 (1359) @ macOS 10.13.4
Prior to printing, the drawing had been fitted and centered from within the Page Layout editor.
Everything else to default.
Regards.
Originally Posted by: jdi000 Hello hatch Can you post a picture or smaple file? Did you print to paper or to a file? Was the drawing scaled to fit a specific paper size? What version 9,10 and what build ? Regards Jason
Hello Hatch I checked windows build 1359 and there is no misalignment on printed output. So this might be specific to mac. But I do not have the exact setup you printed your drawing to. What size paper Is it scaled to fit smaller or bigger? Regards Jason
Can you post or email me the file? Might be how it is converted into Mac screen coordinates if Jason does not see it on Windows. Tim
Hi Tim,
EDIT2: Uploaded VC2 drawing with PNG extension ;-)
EDIT: Ooops ... no vc2 file attachments allowed ... would you mind to PM me you email address?
see the drawing file attached to this post.
Steps: Print => PDF => Save PDF
Edited by user Tuesday, April 24, 2018 5:29:36 PM(UTC)
(534kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Jason,
did you observe that the misalignment starts after the 2nd row of line endings?
Originally Posted by: jdi000 Hello Hatch I checked windows build 1359 and there is no misalignment on printed output. So this might be specific to mac. But I do not have the exact setup you printed your drawing to. What size paper Is it scaled to fit smaller or bigger? Regards Jason
Originally Posted by: hatch Hi Jason, did you observe that the misalignment starts after the 2nd row of line endings?
hatch
Yes, I tried to build a quick test, but it might be better to try the actual file on windows as well.
Hatch
I printed your file, and its ok in windows. I attached a pdf.
ViaCAD 2D _W65C265SQXB.pdf
(90kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
>>some although most line start/end "arrows" are slightly off the line end point which looks weird. This should now be corrected in 1370. The circle arrow head style was updated to use more precision when printing on Mac. Tim
Hi Tim,
where do I get this version from?
Regards.
Originally Posted by: Tim Olson >>some although most line start/end "arrows" are slightly off the line end point which looks weird. This should now be corrected in 1370. The circle arrow head style was updated to use more precision when printing on Mac. Tim
2D Drafting
