flatpack
#1 Posted : Tuesday, April 17, 2018 11:35:06 AM(UTC)
flatpack
I'm unable to use COPY to copy-paste an Angle from the Verify Angle 3pts. User error perhaps? :)
Can't click inside the field..
See attached...
Edited by user Tuesday, April 17, 2018 11:36:31 AM(UTC)  | Reason: Not specified
Screen Shot 2018-04-17 at 12.21.34 PM.png (59kb) downloaded 14 time(s).
#2 Posted : Wednesday, April 18, 2018 3:00:07 AM(UTC)
You can use double click at the field and then when selected press ctrl+c for copy. This works in Build 1369. For A2 works this not, but you can draft with the mouse over the amount and copy this value also.
flatpack
#3 Posted : Wednesday, April 18, 2018 4:06:48 PM(UTC)
flatpack
Thanks, but I unfortunately did already try these to no avail. Maybe my build is too old? I'm using 1359. I seem to always have trouble finding where to download new builds. When I go to Help > Current Version, all it says is that I'm running the latest build.
*To explain a bit further, when I click with the mouse into either A1 or A2 field, nothing happens. It is not recognized as something I can click inside. Also I tried to use the CMD-C (mac) to copy, and again nothing.
Edited by user Wednesday, April 18, 2018 4:11:54 PM(UTC)  | Reason: added more explanation
Screen Shot 2018-04-18 at 5.05.01 PM.png (65kb) downloaded 6 time(s).
#4 Posted : Thursday, April 19, 2018 2:12:42 AM(UTC)
I don't know whether this have to do something with the build number or with Macintosh. But you get downloadlinks of Work in Progress Builds here: http://www.punchcadlabs.com/page7/page7.php
flatpack on 4/19/2018(UTC)
Todd Quinlan
#5 Posted : Monday, April 23, 2018 2:00:15 PM(UTC)
Todd Quinlan
I did some testing, and this seems to be a MAC issue. The PC versions all seem to allow you to click in the fields and copy. I will work with Tim to address this.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
flatpack
#6 Posted : Monday, April 23, 2018 2:06:57 PM(UTC)
flatpack
Understood. Thanks a bunch Todd!
#7 Posted : Wednesday, April 25, 2018 4:41:39 PM(UTC)
Updated in 1370. Mac & PC now behave the same regarding copying these fields.
flatpack on 4/25/2018(UTC)
