digitalphaser
#1 Posted : Tuesday, April 17, 2018 5:48:21 AM(UTC)
digitalphaser
Was thanked: 71 time(s) in 50 post(s)
My main motive for upgrading VC to Shark was more advanced surface modeling tools.
However, it did not help me to speed up the process. I modeled a box for capsules. Guide Cover Tool would be an ideal solution for a convex square cover. But... I spent an hour trying to create a cover with guides. I checked splines for possible problems like gaps etc..., but the surface did not even closely match the curves. To make sure that I'm doing the right thing, I created a test scene. Guide Cover Tool make a topologically more correct surface than Net Surface Tool. But the form of the object is absolutely incorrect.
If I even do something wrong. Why is it so difficult?
With other "advanced" tools is not more better. Disappointment.
digitalphaser
#2 Posted : Tuesday, April 17, 2018 6:05:02 AM(UTC)
digitalphaser
The converting of object created with Guide Cover Tool to Spline Surface is shocked me. Editing is absolutely impossible.
digitalphaser
#3 Posted : Tuesday, April 17, 2018 6:17:17 AM(UTC)
digitalphaser
Converting to mesh. Sometimes I need to do a retopology for WebGL or same things. If I need it, then the NetSurface(green) is more attractive.
Edited by user Tuesday, April 17, 2018 6:18:43 AM(UTC)  | Reason: Not specified
Jolyon
#4 Posted : Tuesday, April 17, 2018 11:00:30 AM(UTC)
Jolyon
Do you want to share the spline-work ... and describe better what you're ideal result would be
I'm sure we can help
Jol
rockyroad_us
#5 Posted : Tuesday, April 17, 2018 1:54:56 PM(UTC)
rockyroad_us
Was thanked: 39 time(s) in 36 post(s)
I think the cover surface with guide makes thinks odd. I think it follows a tangent or takes an average of the curves. Dunno.
Maybe you are better off with guide skin surface using points at the peaks. See result. The net surface works well too.
FX 7-10 Pro12-1576
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
digitalphaser
#6 Posted : Wednesday, April 18, 2018 2:18:28 AM(UTC)
digitalphaser
Jol
Thanks for the help. Now I'm not talking about a specific project. I always had problem with this tool. In most projects Cover w/G feature was not in demand due to low accuracy.
Let's look at a concrete example. I purposely took a few exaggerated form. But I assure you that such shapes are very common in packaging design etc...: portable flexible speakers, spectacle cases, silicone bicycle seat and more more other semi-organic shapes.
guide cover test.sfx (290kb) downloaded 1 time(s).
digitalphaser
#7 Posted : Wednesday, April 18, 2018 2:33:13 AM(UTC)
digitalphaser
Yes, I know. If I change the smoothness of curves (better remove half of points :)), then the cover will take their shape. But this will not correspond to the original form of the object. I'm talking about it. In this case program decides what the form of the object should be. I want the opposite. More precision and flexibility will not be a hindrance.
digitalphaser
#8 Posted : Tuesday, April 24, 2018 10:20:27 AM(UTC)
digitalphaser
Another incomprehensibility. I experienced many the ways but I was not able to cover this frameworke.
Has anyone the desire to try? :)
guide cover test 2.vcp (13kb) downloaded 8 time(s).
rockyroad_us
#9 Posted : Tuesday, April 24, 2018 12:16:02 PM(UTC)
rockyroad_us
You need to understand that the wireframe is not correct due to the small vertical lines. Take a look at what I need using a point too with the net surface. I extended the curves into peaks at the bottom and then you can trim those peaks with another surface that goes across.
guide%20cover%20test%202.vcp (301kb) downloaded 5 time(s).
FX 7-10 Pro12-1576
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
digitalphaser
#10 Posted : Tuesday, April 24, 2018 12:35:55 PM(UTC)
digitalphaser
Thank you @rockyroad_us. But... Anyway, I can not do it. Can you please attach shark file?
rockyroad_us
#11 Posted : Tuesday, April 24, 2018 1:10:28 PM(UTC)
rockyroad_us
attached in my previous response.
FX 7-10 Pro12-1576
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
Jolyon
#12 Posted : Tuesday, April 24, 2018 1:15:53 PM(UTC)
Jolyon
As stated - not all of those lines can be 'hard'
Which are critical ?
Jolyon attached the following image(s):
iffy jol.jpg (44kb) downloaded 2 time(s).
digitalphaser
#13 Posted : Tuesday, April 24, 2018 1:19:30 PM(UTC)
digitalphaser
Thanks. :)
