flatpack
#1 Posted : Thursday, April 12, 2018 9:59:14 AM(UTC)
flatpack
Was thanked: 20 time(s) in 15 post(s)
VC 10 Pro:
Issue 1)
When I change the color of an objects face, and try to check what color it is later, the ORIGINAL color shows up in the color palette. Not the color it actually is.
Issue 2)
Then when I try to use the Eyedropper on that face to transfer that same custom color onto a new face, once again the ORIGINAL color is what is transferred.
Am I doing something wrong? Need to do this for export for rendering.
Thanks!
#2 Posted : Thursday, April 12, 2018 1:21:38 PM(UTC)
>>When I change the color of an objects face, and try to check what color it is later, the ORIGINAL color shows up in the color >>palette.
This is now updated in 1370 to work with deep select and Inspector/Pen Color. Working next on floating color palette...
For 1370, it will now grab the underlying FROM face color but will apply to the entire TO body. Perhaps later we can add a control key or option to specify whether the drop is to a individual face or entire body.
flatpack on 4/12/2018(UTC)
flatpack
#3 Posted : Thursday, April 12, 2018 3:10:24 PM(UTC)
flatpack
Noted with thanks!!
