2D Drafting
Dimensions and text vertical
Hi forum,
I'm having a very odd time tweaking my defined styles and, layers and views. Once I think I've solved one issue, another one pops up! So confusing!
Now, for some reason - all text and dimensions appear vertical - despite being designated at horizontal?
Any thoughts why this is happening?
Miles
polymer8 attached the following image(s):
(237kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 21 times Was thanked: 16 time(s) in 15 post(s)
Hello Polymer, Many forum members are complaining about the dimensions setting and interface. There are so many points to solve, or improve in the palette... In your case, the dimensions seem to follow a specific workplane you have set. Go to the workplane menu and put it back to global... JL
1 user thanked jlm for this useful post.
Thanks Jim, I'm also playing around with the startup.dat file to set up pen properties for each layer. Can't make much sense of it as not much sticks when I reopen a new file. My newly created pen styles remain (as I can't edit the existing ones), but they are non-associated with each layer! I've tried using the 'override pen styles' in the layers palate, but the startup.dat doesn't keep these settings either. So a basic, basic question. How can I create a default file with pen styles associated with layers? Miles
Was thanked: 178 time(s) in 158 post(s)
>>all text and dimensions appear vertical - despite being designated at horizontal? Hello Miles Can you post the ViaCAD file where the text is vertical and you've specified horizontal? Thanks Tim
>>I've tried using the 'override pen styles' in the layers palate, but the startup.dat doesn't keep these settings either. Can you post your startup.dat file? Thanks Tim
Was thanked: 62 time(s) in 60 post(s)
Here is Startup.dat, all the custom pen types and layers are saved but not the pen style applied to the layers
Edited by user Thursday, April 05, 2018 3:04:41 PM(UTC)
| Reason: files
startup.zip
(1kb) downloaded 3 time(s). jdi000 attached the following image(s):
(23kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Windows 10, Win 7
Originally Posted by: jdi000 Tim Here is Startup.dat, all the custom pen types and layers are saved but not the pen style applied to the layers Thanks Jason
Hi Jason, tim
I loaded Jason's startup.dat file into my Shark LT 9 resources folder and did a relaunch.
This is a screen shot of what I've got. Again. pen styles are not associated with layers.
miles
Edited by user Thursday, April 05, 2018 8:17:06 PM(UTC)
(302kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Tim Olson >>I've tried using the 'override pen styles' in the layers palate, but the startup.dat doesn't keep these settings either. Can you post your startup.dat file? Thanks Tim
Hi Tim,
Thanks for attending to my dilemma. Attached is the startup.dat file.
Edited by user Thursday, April 05, 2018 8:15:57 PM(UTC)
startup.dat.zip
(6kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Tim Olson >>all text and dimensions appear vertical - despite being designated at horizontal? Hello Miles Can you post the ViaCAD file where the text is vertical and you've specified horizontal? Thanks Tim
Hi Tim,
Jim, responded to this matter and offered a remedy.
But I'm still not sure why the workplane needs to be reset to global solves the problem?
Miles
>>But I'm still not sure why the workplane needs to be reset to global solves the problem? Dimensions are defined in a 2D coordinate system where x defines the horizontal direction. When creating dimensions, this 2D coordinate system is the WorkPlane. Resetting the workplane put it back aligned with the global coordinate system. Tim
Thanks: 2 times Was thanked: 21 time(s) in 16 post(s)
Quote: Many forum members are complaining about the dimensions setting and interface. There are so many points to solve, or improve in the palette...
+1
>>Here is Startup.dat, all the custom pen types and layers are saved but not the pen style applied to the layers Repeated, found, and fixed in 1370. Thanks for the heads up all! Tim
2D Drafting
