#1 Posted : Saturday, April 07, 2018 1:18:56 AM(UTC)
Was thanked: 27 time(s) in 23 post(s)
Morning all,
So we are in Shark using the GD & T tool. Is there a way to add a symbol such as # to the box marked in the image so it picks up the hole size? The tool is great, one of the reasons I pushed to get the upgrade, but obviously if I manually type in the hole size, which isn't normally a problem, and then I change the hole size, then it's not going to up date.
I mention the # because that is what seems to pop up when you label a hole.
Is this possible? If not is this an option for the future?
Cheers
Is there a way.jpg (36kb) downloaded 2 time(s).
ViaCAD Pro 10 + Power Pack Pro
mitchb
#2 Posted : Saturday, April 07, 2018 10:34:41 AM(UTC)
mitchb
Was thanked: 15 time(s) in 11 post(s)
The way to do this is to not use the size box at all. Use the appropriate dimensioning tool and suppress the size box. Compose the frame and place it. And a bonus to this is a fit symbol can also be used.
Screen Shot 1.png (331kb) downloaded 16 time(s).
#3 Posted : Saturday, April 07, 2018 10:42:21 AM(UTC)
Hi mitchb
Yeah that's what I've been doing, but thought they may be another way so we can do it all in one hit?
Cheers
