Drag n Drop makes file sizes go INSANE
Hi all, just been dragging and dropping some obj files into Shark, and noticed it was getting a little excited! checked the size, and wooooa hang on a minute, they are HUGE!
(62kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
UG I don't think obj files contain units in the file definition at all, so drag an drop would not know what to size them as? Other than prompt the user. Regards Jason
>>I don't think obj files contain units in the file definition at all Yup. OBJ, STL, 3DS, some old DWG/DXF formats do not have units and will drag/drop using the current file unit settings. File : Import has a user interface that lets you specify the unit of the incoming file. Tim
No worries, I shall keep in mind and use as appropriate. Cheers
