#1 Posted : Thursday, March 29, 2018 4:18:47 PM(UTC)
Was thanked: 94 time(s) in 75 post(s)
Evening all,
I have a mesh which I've created in Topogun 2, so it's a nice quad mesh. I've added images below. My question is, when I use mesh to subd, I get the second attached image, what is causing it to 'split up' the surfaces as shown? Is there a way to create a nice full 'clean' surface here?
FULL BLADE.zip (271kb) downloaded 4 time(s).
Quad Mesh -1.jpg (288kb) downloaded 8 time(s).
Mesh to NURB -1.jpg (54kb) downloaded 9 time(s).
Shark CAD + Power Pack Pro
digitalphaser
#2 Posted : Thursday, March 29, 2018 5:29:39 PM(UTC)
digitalphaser
Was thanked: 58 time(s) in 42 post(s)
SharkCAD like a simple mesh. Ideally with not subdivided clean quad topology. Your simple model has an unreasonably complex mesh. Here 10-20 polygons are enough. In this case, Shark calculated correctly.
#3 Posted : Friday, March 30, 2018 10:47:46 AM(UTC)
Was thanked: 234 time(s) in 203 post(s)
It looks like some of the quads have collapsed edges. Plus some of the quads have flipped normals.
Do you have any control in Topogun to refine this area into smoothly flowing quad paths?
Vice President Software Development
#4 Posted : Friday, March 30, 2018 10:57:17 AM(UTC)
Hi Tim,
You can manually delete the points and put in new edges. So when you subdivide it goes a bit made, like you can see. So you can go in and edit.
Thought I ran a repair on this mesh! Obviously not! :-)
#5 Posted : Friday, March 30, 2018 11:05:41 AM(UTC)
Same here. I'm looking now into why the flipped normals were not repaired.
Edited by user Friday, March 30, 2018 11:07:45 AM(UTC)  | Reason: Not specified
UGMENTALCASE on 3/30/2018(UTC)
