schrubi64
#1 Posted : Sunday, January 23, 2011 2:18:12 PM(UTC)
schrubi64
Switzerland
Hello Forum
I would like to create Drawings of several parts of an assembly.
Due to its function some of the parts are placed inclined to the axes
of the coordinate system.
If I pick such a part and create a Drawing with the model-to-sheet function
the part is automatically placed representing its position in the assembly.
What is the proper way to place such parts with to the axes aligned edges?
In other CAD programs I can define the axes of the drawing view depending on edges of the part. Does ViaCAD also have a similar function?
Thanks and regards,
Beat Schreiber
ViaCAD Pro 7 Beta (V.6.0.0 Build 959)
Windows 7 Home Professional
chipmaker2
#2 Posted : Sunday, January 23, 2011 9:42:31 PM(UTC)
chipmaker2
Hey Beat Schreiber
Orient the part in the 3D as you want in it in your sheet mode. In the view menu click on "New View". In "New View" name it (my View) and hit apply button in the dialog box. Now when your in sheet mode click on a view then right click and click "change view". Pick "my view" from "User View" and your there.
Chuck
Hey Beat Schreiber
Richten Sie den Teil in der 3D, wie Sie mchten in es in Ihrem Blatt-Modus. Im Men "Ansicht" klicken Sie auf "New View". In "New View" nennen es (meiner Meinung nach) ein und drcken die Schaltflche bernehmen in dem Dialogfeld. Nun, wenn Ihr in Blatt-Modus klicken Sie auf einen Blick, dann die rechte Maustaste und klicken Sie auf "Ansicht ndern". Pick "meiner Ansicht nach"von "Benutzer anzeigen"und Ihr dort.
Chuck
David Gross
#3 Posted : Monday, January 24, 2011 9:49:04 AM(UTC)
David Gross
Create a work plane on a face of your model, then view the plane, then save the current view, then do the model to sheet, then change the view of your sheet to the view you saved.
David Gross
Dmg Design
Colgate, Wi.
schrubi64
#4 Posted : Monday, January 24, 2011 12:44:59 PM(UTC)
schrubi64
Switzerland
Thank you Chuck.
This is a practicable way and if I don't have applicable edges I can draw a temporary triade or crosshair.
Regards,
Beat
hans
#5 Posted : Monday, February 7, 2011 7:10:53 PM(UTC)
hans
Originally Posted by: chipmaker2 Go to Quoted Post
Hey Beat Schreiber
Chuck
Thanks as well. I had the same problem and was about to ask :)
hans
