Partial Select in Shark not working on a mesh
Is anyone else seeing this? I've reported it as a bug, but wanted to see if anyone else is seeing it? I've attached two videos. One is in VC and a partial select on a mesh works fine. Same setting, same mesh etc. doesn't work in Shark.
Shark Select.mp4
(1,309kb) downloaded 10 time(s). VC Select.mp4
(1,572kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Seems to work O.K. on Shark 1368 PC.
(113kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Ah ok, maybe it's just the version I have. I've got 1335, or 55 which ever but its the latest official release. Cheers
Originally Posted by: UGMENTALCASE Ah ok, maybe it's just the version I have. I've got 1335, or 55 which ever but its the latest official release. Cheers
Tim Olson told you already how to get 1368 and that the WIP is not a Beta version. But you just on 1335... This i can't understand. The Download from Punch works not correctly. Sometimes there you get a Shark Cad Download instead of a Shark Cad Pro Download. But The Shark Cad Download File is Called Shark Cad pro but de facto Shark CAD will be installed. Bought you Shark Cad or Shark Cad Pro???? 1335 is almost a year there for download and maybe yet shark cad instead of shark cad pro and contrariwise.
Edited by user Wednesday, March 28, 2018 6:47:23 AM(UTC)
Yes he has, but I use the link out of the software, and if it tells me there's no update then there's no update as far as I'm concerned. I'm on 1335 because thats what I was given when I bought Shark, not that long ago. Isn't WIP 'work in progress' and therefore not an official release? I'll stick to the official releases when they work out of the links. Cheers
Originally Posted by: UGMENTALCASE the link out of the software
You mean Help> Current Version? Read the changelog in the Beta thread what made since 1335.
http://forums.punchcad.c...sts&t=8351#post31852 And then think about whether it's better to use a WIP Version than the official version. The WIP 1335 is not more stable than the official 1335 Build, 1335=1335 and 1335 was Beta. And When the developer say that the 1368 is a stable version, you can trust him.
Edited by user Wednesday, March 28, 2018 7:23:50 AM(UTC)
Yes that's the link I use. I didn't get much choice with this version I have. I bought Shark and that's what I got. Guess I'll wait or go through that link and check that before I ask any questions. Thanks
I also have reported this, this started in V9 its like the model is asleep, doesn't always happen but when it dose I have to do a select all and move the models .0000 and then it will start working again for a while. I think it is related to the fact that smart silhouettes don't work all the time either so there's no lines to cross over.
David Gross Dmg Design Colgate, Wi.
1 user thanked David Gross for this useful post.
Originally Posted by: MPSchmied Originally Posted by: UGMENTALCASE the link out of the software
Can't see anything that relates to what I'm saying here.
