NeuTechFLA
#1 Posted : Friday, March 9, 2018 2:35:46 PM(UTC)
NeuTechFLA
Interesting....
#2 Posted : Friday, March 9, 2018 7:19:59 PM(UTC)
Was thanked: 303 time(s) in 205 post(s)
If you select the bits, then right click and select 'show direction', on the mirrored side, is it opposite to the non mirrored? If so you can right click and 'change direction'
I've noticed on rotation patterns that the work plane needs to be in a certain direction for it to work as desired, this could be another option to try and change?
