NeuTechFLA
#1 Posted : Wednesday, March 07, 2018 12:31:55 PM(UTC)
NeuTechFLA
Was thanked: 21 time(s) in 10 post(s)
I am trying to change the shell from 3.0mm to 3.5mm. Is this impossible?
NeuTechFLA
#2 Posted : Wednesday, March 07, 2018 12:36:33 PM(UTC)
NeuTechFLA
Once again, 26 seconds after I post, I find the answer. Sorry for the bother.
Edited by user Wednesday, March 07, 2018 12:38:37 PM(UTC)  | Reason: Not specified
#3 Posted : Wednesday, March 07, 2018 12:37:21 PM(UTC)
Was thanked: 75 time(s) in 73 post(s)
Hello
Their depends on what geometry was modified after the initial shell. You can suppress features in the tree and try to change shell and then unsupress.
It really depends on the geometry interactions. If you post a file someone can look at it closer.
Windows 10, Win 7
horst.w
#4 Posted : Wednesday, March 07, 2018 12:46:15 PM(UTC)
horst.w
Was thanked: 18 time(s) in 16 post(s)
No problem, it is running fine for me.
horst.w
GER
ViaCAD 9 Pro german + ViaCAD 10 Pro & PowerPack + ViaCAD 11, Win 7 Prof 64 Bit
thanks 1 user thanked horst.w for this useful post.
NeuTechFLA on 3/7/2018(UTC)
NeuTechFLA
#5 Posted : Thursday, March 08, 2018 7:00:35 AM(UTC)
NeuTechFLA
Somewhat different.
