ALBANO
#1 Posted : Tuesday, February 27, 2018 8:52:04 AM(UTC)
ALBANO
Hello Tim and friends,
isn´t it time to take the next step?
CAD was once the choice for manufacturers to speed up part definition because processing power had evolved so that it was possible .
Nowadays processing power is sufficient to do even simulations on the fly!
I have downloaded Algodoo (free) for my sons to play with. You can simulate and try nearly every problem you can think of in 2D.
Then i discovered that they have a 3D library as well (https://www.algoryx.se/products/agx-dynamics/#tab-1)
AND I can not design as intuitive and easy as in this fun-Simulator!!!
I ever so often stumble across dynamic functional problems when designing mechanical parts in shark.
And nothing is more tedious than changing an object consisting of say 100 operations just because something wasn´t thought of in the beginning.
Please check out if that was possible to integrate into shark. Maybe as part of powerpack? Or even simulatorpack?
I would pay extra for that capability!
Alban
