Jolyon
#1 Posted : Saturday, February 24, 2018 10:51:20 AM(UTC)
Jolyon
Extruding a solid from a non-planar profile
Can you do it - or can't you ?
It's really just the inconsistency I'm struggling with ...
1. - Take a non-planar profile - you CAN'T extrude it !
However, make a non-planar surface (eg. cover surface)
2. - You CAN'T extrude it using the 'by distance' option (say 20mm)
3. - But you CAN extrude it using the 'by vector' option (same 20mm)
So - my question is - why the difference ?
You clearly CAN extrude a non-planar profile into a solid
Why then is the extrude tool lying to me in points 1 & 2 above
Shouldn't we be striving to strip out such inconsistencies (- if only by adding the workaround to the error dialog)
Jol
Edited by user Saturday, February 24, 2018 10:52:49 AM(UTC)  | Reason: Not specified
Jolyon attached the following image(s):
not planar.jpg (18kb) downloaded 4 time(s).
thanks 1 user thanked Jolyon for this useful post.
L. Banasky on 2/24/2018(UTC)
L. Banasky
#2 Posted : Saturday, February 24, 2018 12:25:23 PM(UTC)
L. Banasky
Was thanked: 141 time(s) in 100 post(s)
Hi Jol,
Thanks for a very handy work around, the Curves Not Planar Pop Up appears a lot for me.
Strange, if you Delete the Cover Surface, you have an extruded non planar solid.
Edited by user Saturday, February 24, 2018 5:42:40 PM(UTC)  | Reason: Not specified
Non Planer Extruded Solid.jpg (35kb) downloaded 0 time(s).
murray
#3 Posted : Saturday, February 24, 2018 4:31:37 PM(UTC)
murray
Extrude by distance assumes a "normal" extrude, ie what would be normal to a planar surface. Non-planar surfaces don't have an obvious normal, but a definite vector removes the ambiguity.
