Art Smith
#1 Posted : Thursday, January 25, 2018 5:48:25 PM(UTC)
Art Smith
the "guy" operating the "tap" this morning clearing wasn't paying attention; see attached image upper left insert. being the "afternoon guy" and an eternal optimist I assumed the fix for the incorrectly tapped hole was a "deep select" and a text box adjustment away........................ see attached image upper right insert. no amount of pleading, muttering, or changing the values in the text box had any effect on the tapped hole representation!
am I doing something incorrectly?
...known problem??
...functionality that doesn't exist yet???
how is the problem best corrected? it's far too many operations in the past to "undo".
Art
artesmith@earthlink.net
thread tool question.jpg (51kb) downloaded 19 time(s).
murray
#2 Posted : Thursday, January 25, 2018 8:44:58 PM(UTC)
murray
Fill the hole(boolean addition)/delete face/s/defeature and redo to spec?
mitchb
#3 Posted : Friday, January 26, 2018 7:59:09 PM(UTC)
mitchb
Select the thread with the "Select Deep" tool and change the pitch in the Pitch data box. You can also select the thread in the "Entities" list and use the Inspector, curiously the pitch entered here must be twice the desired amount. Entered in the data window data box works as expected.
mitchb attached the following image(s):
Screen Shot 1.png (438kb) downloaded 7 time(s).
thanks 1 user thanked mitchb for this useful post.
Art Smith on 1/27/2018(UTC)
Art Smith
#4 Posted : Saturday, January 27, 2018 1:00:52 AM(UTC)
Art Smith
mitchb-
pitch isn't my problem; the thread is too short. per your suggestion I tried the Inspector approach to no avail. the software goes off and thinks for a while before coming back with no change............
Art
thread tool question response 01-26-2018.jpg (68kb) downloaded 5 time(s).
#5 Posted : Saturday, January 27, 2018 2:05:44 AM(UTC)
By the sounds of it, it doesn't like a process that comes after the tapped hole. Has the surface over the hole been cut or anything like that, I'm just thinking it might not be able to figure out where the hole starts or something, therefore can't do it. You could try changing it to left handed and see if that will allow any mods, then change it back?
I'd be filling it in and doing it again, not ideal but something after the tapped hole is, I believe, causing the problem.
Other than that, it's definately a internal thread? I've accidently put a external thread in a hole, and changing it never worked, then I realised what had happened and started it again.
*edit*
I've just done a test. if you select the part, right click the thread in the history, and select 'replace solid' that will fill in the hole without adding more bits. will this work for you? Then just put the hole in again?
Edited by user Saturday, January 27, 2018 2:41:32 AM(UTC)  | Reason: more information added
mitchb
#6 Posted : Saturday, January 27, 2018 3:08:58 AM(UTC)
mitchb
I'm thinking that there is another surface down in the hole that the thread tool is using as a start point. Try making the hole while holding the control key to set an associative point to the hole and use that for the thread start point.
Art Smith
#7 Posted : Tuesday, February 20, 2018 10:54:59 AM(UTC)
Art Smith
another "PowerPack/Modify/Thread" tool opportunity/challenge (aka: problem. without regard to the specified thread depth, the thread tool is providing on the order of 3/4's of one thread.... an overview chart AND file are attached. thanks
Art
Edited by user Tuesday, February 20, 2018 10:57:35 AM(UTC)  | Reason: Not specified
collector plate fault isolation.sfx (45kb) downloaded 3 time(s).
thread tool fault isolation.jpg (34kb) downloaded 6 time(s).
mitchb
#8 Posted : Tuesday, February 20, 2018 2:11:43 PM(UTC)
mitchb
Change the length to -0.750. The orientation of your part is upside-down.
Screen Shot 1.png (234kb) downloaded 0 time(s).
Art Smith on 2/20/2018(UTC)
Art Smith
#9 Posted : Tuesday, February 20, 2018 3:00:05 PM(UTC)
Art Smith
mitchb-
THANKS, that's got it!! changed the length but never thought to try the sign bit............
Art
