2D Drafting
Can't add a rad dim on a lathe solid
I've just started a drawing of a lathe solid, which has rads on it. Started the drawing, can't select the rads for a dimension! If I section it I can then add the rads. If you create a basic shape, and then stick a rad on one of the ends, and try and dimension it, I can't get it to work! ViaCAD v10 Pro Windows 7 Pro
Hello UG Can you post a pic or a sample file? Did you use smart dimension tool or the specific diameter or radius dimension tool? Regards Jason
it doesn't work with either smart or rad dim tools. I've done a very basic example. It's saved on the drawing, and if you try and add a dimension nothing happens.
Cheers
Example file.vcp
(62kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
It works if you switch to precise curves.
(79kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
UG In ViaCAD you can change the view to shaded add dimension then switch back Regards Jason
Hi L.Banasky, I don't have shark so unfortunately that option I do not have. I'll have a look at changing the view Jason, cheers. Just been struggling to add them to a section view also. Only Smart dim would work.
2D Drafting
