#1 Posted : Wednesday, February 14, 2018 9:33:11 AM(UTC)
I've just started a drawing of a lathe solid, which has rads on it. Started the drawing, can't select the rads for a dimension! If I section it I can then add the rads. If you create a basic shape, and then stick a rad on one of the ends, and try and dimension it, I can't get it to work!
ViaCAD v10 Pro
Windows 7 Pro
#2 Posted : Saturday, February 17, 2018 10:05:11 AM(UTC)
Hello UG
Can you post a pic or a sample file? Did you use smart dimension tool or the specific diameter or radius dimension tool?
#3 Posted : Saturday, February 17, 2018 10:23:47 AM(UTC)
it doesn't work with either smart or rad dim tools. I've done a very basic example. It's saved on the drawing, and if you try and add a dimension nothing happens.
Cheers
Example file.vcp (62kb) downloaded 6 time(s).
L. Banasky
#4 Posted : Saturday, February 17, 2018 1:32:44 PM(UTC)
L. Banasky
It works if you switch to precise curves.
#5 Posted : Saturday, February 17, 2018 1:49:34 PM(UTC)
UG
In ViaCAD you can change the view to shaded add dimension then switch back
#6 Posted : Saturday, February 17, 2018 3:16:42 PM(UTC)
Hi L.Banasky, I don't have shark so unfortunately that option I do not have. I'll have a look at changing the view Jason, cheers.
Just been struggling to add them to a section view also. Only Smart dim would work.
