luk72
#1 Posted : Monday, January 01, 2018 4:59:22 PM(UTC)
luk72
Was thanked: 10 time(s) in 5 post(s)
Please, try to do coffe cup like Tim :)
Enjoy. VCPRO 10.0.4 b(1345) w. PP10
Edited by user Monday, January 01, 2018 5:06:24 PM(UTC)  | Reason: Not specified
Untitled 1.vcp (16kb) downloaded 17 time(s).
vcpro_v10-subd problem coffe cup_cut.mp4.mp4 (962kb) downloaded 23 time(s).
#2 Posted : Tuesday, January 02, 2018 3:14:48 AM(UTC)
Was thanked: 98 time(s) in 78 post(s)
Works fine. The only thing suspicious about the video is that when you drag the blue arrow down, the edge directly behind it doesn't behave. Try rotating you view first so there's either nothing behind or no edges etc. Mine worked fine whether there is something behind it or not, but I can't see anything else wrong here?
Untitled 1.vcp (24kb) downloaded 4 time(s).
Untitled 1.jpg (73kb) downloaded 3 time(s).
Shark CAD + Power Pack Pro
luk72
#3 Posted : Tuesday, January 02, 2018 10:20:57 AM(UTC)
luk72
Thanks 4 answer, but works fine when i only drag blue arrow. Problem is when i use also "ctrl" drag for copy, and drag.
Still not solved. Enjoy.
Edited by user Tuesday, January 02, 2018 10:22:23 AM(UTC)  | Reason: Not specified
digitalphaser
#4 Posted : Wednesday, January 03, 2018 4:37:14 AM(UTC)
digitalphaser
Was thanked: 60 time(s) in 44 post(s)
I did not see any problems with your cup too. It works fine to me. But really this SubD tool is very cranky. When you work with subdivision, disable "Snaps": Face On, To Grid, Work Plane. Sometimes it helps.
thanks 1 user thanked digitalphaser for this useful post.
GARLIC on 1/3/2018(UTC)
#5 Posted : Wednesday, January 03, 2018 7:18:14 AM(UTC)
Tried again and mine goes even crazier than yours!
luk72
#6 Posted : Saturday, February 10, 2018 9:57:54 PM(UTC)
luk72
Solution! a bug is for sure. See video. Enjoy.
vcpro_v10-subd problem coffe cup2.mp4.mp4 (1,648kb) downloaded 20 time(s).
