Antoine
#1 Posted : Wednesday, February 07, 2018 3:39:21 AM(UTC)
Antoine
Switzerland
Was thanked: 22 time(s) in 17 post(s)
Hello,
it is not possible to fill the selected area with color ...
This works however with hatching.
Do you have an idea or a solution to get there?
Thank you.
https://www.screencast.com/t/rIxh6vwlfOf
Antoine
www.mrconcepts.ch
www.design-r.ch
SharkFX 10
MacOS 10.13.5
Mac Pro 2,7 GHz 12-Core Intel Xeon E5
AMD FirePro 6144 Mo
Jolyon
#2 Posted : Wednesday, February 07, 2018 3:47:48 AM(UTC)
Jolyon
Was thanked: 16 time(s) in 15 post(s)
Hi Antoine
I see the same here - I would expect the 2 tools to work similarly
Jol
#3 Posted : Wednesday, February 07, 2018 4:20:02 AM(UTC)
Was thanked: 35 time(s) in 29 post(s)
I've just tried it and it seems to work ok. Although no amount of clicking after I've deselected the fill, will allow me to re-select the fill, nor get rid of it in the tree?
ViaCAD Pro 10 + Power Pack Pro
Shark CAD + Power Pack Pro
Antoine
#4 Posted : Wednesday, February 07, 2018 7:57:26 AM(UTC)
Antoine
Switzerland
witch version of Shark plz?
www.mrconcepts.ch
www.design-r.ch
SharkFX 10
MacOS 10.13.5
AMD FirePro 6144 Mo
#5 Posted : Wednesday, February 07, 2018 8:12:32 AM(UTC)
using ViaCAD V10 Pro on windows 7, not shark sorry :-)
Todd Quinlan
#6 Posted : Wednesday, February 07, 2018 9:00:03 AM(UTC)
Todd Quinlan
While the Hatch is its own entity and can simply be deleted by selecting it and deleting, the fill tool reacts a bit differently.
The steps to remove a fill depends on how the original profile was created and the tool used to fill it.
-If you created a single line profile (including a circle as its considered a single line from 3 o'clock, counter clockwise back around to 3 again.), and used the fill tool itself, The program creates a polygon using the line work then fills it. Too remove this type of fill, click the profile and delete the polygon. This will leave you with the original line work.
-If you create a profile using a smart polygon and then using the inspector to fill it. Select the polygon and go back into the inspector and change the fill pattern to none.
As far as the original issue reported in this thread, it does seem to be a bug. The fill should recognize both boundaries and only fill between them as the hatch tool does. I have pass this along to Tim to take a look at.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
Antoine
#7 Posted : Tuesday, February 13, 2018 3:26:16 AM(UTC)
Antoine
Switzerland
Tank you Todd
www.mrconcepts.ch
www.design-r.ch
SharkFX 10
MacOS 10.13.5
AMD FirePro 6144 Mo
Guest (6)
