Somebody put me out of my misery please
My question is about associativity and why when I iterate (ie. even to change the nature of a defining spline minutely), I must delete my surfaces and solids, 'remove links' and rebuild my object from the driving curves.
In order to illustrate this, I have made a very simple model - we can call it the 'butter dish lid' (attached)
It uses a series of intersecting surfaces, which I trim back to one-another and stitch into a solid
(The method is exactly the same as I use to create enormously complex free form shapes, which I can then feature with holes, bosses, and rad blends and then shell)
So the problem ... I expect to be able to utilise 'associativity' in my 'drive curves' to affect the surfaces, in turn modifying the surface intersects (and of course trims), thus in turn redefining the perimeter of the 'butter dish lid'. (... Ultimately this would naturally update a 'stitched solid', several feature holes perhaps, some bosses and then rad blends and ultimately the shell, let's say).
Should just work, right !?
Model is attached - You'll see that if you adjust one or more of the splines (in the plan view), the surfaces will update - as will their intersections to one another ... Great !
One more note - I have not put a cover surface on the bottom of the butter dish lid, so you'll be unable to stitch it into a solid until you do. This may be where the problem lies.
If you do add the necessary cover surface - (and go back to the top view) - you will see that you can no longer adjust the driving spines and have the driven surfaces and intersects recalculate. (A given spline point will just nonchalantly return to where they were before you tried to move it).
Further, if you stitch your 6 surfaces into a solid - you will then encounter error dialogs (and the adjustment will fail as before)
At this point, in a live project, knowing I must adjust a driving spline, I would normally dump the surfs / solids and remove all links before rebuilding - but this simply CANNOT be right. I waste days rebuilding and rebuilding and rebuilding.
So what am I doing wrong ?
Help Meeee !
 butter dish lid.sfx
(61kb) downloaded 8 time(s).Jolyon attached the following image(s):
(60kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
