History of parts - integrity thereof
For me - there are integrity issues with the history of parts - whilst these show up less and less as the app develops ... you're still forever stepping around them and they need fixing. I suspect they aren't so easy to fix. Shark / VC is hugely forgiving and allows you to carry on when a part's integrity is broken - this is both good and bad I suppose depending on your outlook. When iterating, I'm often trashing my surfaces & solids, removing all links and rebuilding again clean. I simply shouldn't have to be doing this. This for me is where the developers really need to focus. Jol
Also - The History Explorer (or whatever we call it now) - for me - is extremely difficult to navigate for anything but the simplest part. If you 'hollow select' a blend for example on your model - then why does it not spring up - highlighted - in your History Explorer ? ... Perhaps even greying out the bits that aren't selected - in order to simplify
On a smaller point - details are important ! - why does the History Explorer report ... - a construction line as a drawn line ? - a variable blend as a contact blend ? - a wall (single) as a wall (multiline) ? etc Less detail make getting around the history tree harder than it need be
I've noticed the change in names on things. Bit confusing when you do a curve connect, and it comes up as a join (think that's the right way round when I saw it)
The history of a part is like a recipe, right ? You have ingredients and you have instructions Shark / VC should be able to regenerate that part exactly at any time from the list of ingredients ... and said instructions I should be able to click any part and ask to play a 'movie' - where it's easy to step through the build process (pausing where necessary to inspect ... and adapt) from inception to completed part. I want this - so that I can fully understand and adapt complex part history of my - and other people's parts This may also help us fix the holes in Part History where associativity is failing us ! Jol
As I remember, Solidworks has a step-through mode for viewing a part's history ... Can't we ?
Thanks: 31 times Was thanked: 27 time(s) in 12 post(s)
I also find the History tree, Model Tree, Explorer...uh whatever that "thing" over there on the right is called to be cumbersome and lacking. I would like to see a multiple item select and an "insert mode" type slider (like Creo and SolidWorks) that will "suppress" items as the slider is slid upward and resumes as the slider is pulled downward. Don't get me started on Unresolved Links. Creo has a model player as well but the insert mode slider works somewhat the same.
