AndreasH
#1 Posted : Tuesday, January 02, 2018 7:30:58 AM(UTC)
AndreasH
Hi guy´s sorry for my english I´ll give my best :-)
I want to create a Solid from two polygons with different Z height wich I have created from arc & lines there
is no way to get an even distribution of the surface around the edges.
I tried several ways like changing the direction of the acrs and lines or convert arcs to beziers.
Also i tried to use differnt paramters to create the skin solid in the Options menue.
I have attched some images to show yo my problem.
AndreasH attached the following image(s):
GARLIC
#2 Posted : Tuesday, January 02, 2018 8:01:27 AM(UTC)
GARLIC
Was thanked: 12 time(s) in 10 post(s)
could you upload the basic geometry / boundary curves ?
for some testing ...
regards
G.
AndreasH
#3 Posted : Tuesday, January 02, 2018 8:16:48 AM(UTC)
AndreasH
This is the basic geometry / Units Metric mm
Andy
basicTest.vcp (8kb) downloaded 3 time(s).
Jolyon
#4 Posted : Tuesday, January 02, 2018 8:21:42 AM(UTC)
Jolyon
Was thanked: 10 time(s) in 9 post(s)
I would add the radius blends as features afterward !
AndreasH
#5 Posted : Tuesday, January 02, 2018 9:20:44 AM(UTC)
AndreasH
Thank you !
This comes very close with elipytical Fillet, but how can i prevent the undersite edge to get rounded with.?
Jolyon
#6 Posted : Tuesday, January 02, 2018 1:45:08 PM(UTC)
Jolyon
Well done ...
Press the option key (Mac) within the elliptical blend tool
Turn OFF 'automatic chaining' and select just the edge you want
Jol
AndreasH
#7 Posted : Tuesday, January 02, 2018 3:37:25 PM(UTC)
AndreasH
Sorry Jol ... unchecking this option doesnt´t help.
I tried the variable blend linear funktion, but it doesnt´t follow the inner arc exactly .
Andy
#8 Posted : Tuesday, January 02, 2018 4:28:14 PM(UTC)
Was thanked: 53 time(s) in 51 post(s)
Hello Andy
Is this what you are looking for see attached file.
basicTest2mod.vcp (3,843kb) downloaded 1 time(s).
Windows 10, Win 7
AndreasH
#9 Posted : Tuesday, January 02, 2018 5:03:50 PM(UTC)
AndreasH
Hi Jason !
Thank you !
The corners are looking good, but it seems that the surfaces along are concave or am I wrong ?
I need flat ( plain ) surfaces along the sides
Andy
Edited by user Tuesday, January 02, 2018 5:11:52 PM(UTC)  | Reason: Not specified
Jolyon
#10 Posted : Tuesday, January 02, 2018 6:54:40 PM(UTC)
Jolyon
Then - best way is to build all your surfaces manually as 4 sided patches, then stitch it together into a solid !
Jol
thanks 1 user thanked Jolyon for this useful post.
AndreasH on 1/3/2018(UTC)
#11 Posted : Tuesday, January 02, 2018 9:02:47 PM(UTC)
Andy
Here is another try see if this is what you wanted.
basicTest2mod2.vcp (3,940kb) downloaded 4 time(s).
Windows 10, Win 7
digitalphaser
#12 Posted : Wednesday, January 03, 2018 4:07:54 AM(UTC)
digitalphaser
Was thanked: 10 time(s) in 10 post(s)
If I understood correctly, then for corners I would use a Skin Surface tool Arc to Point. Then stitching to solid.
skinning.vcp (336kb) downloaded 4 time(s).
thanks 1 user thanked digitalphaser for this useful post.
Jolyon
#13 Posted : Wednesday, January 03, 2018 8:16:50 AM(UTC)
Jolyon
Thing about geometry is - there are infinite possibilities !
You will likely have to try several approaches to get the answer you want
Experience helps greatly with this
You're doing great !
rockyroad_us
#14 Posted : Wednesday, January 03, 2018 10:52:23 AM(UTC)
rockyroad_us
You could try the loft surface command with 0 bulge to give flat surfaces. In the corners, you need points however. so you loft between the curve and a point.
FX 9-1224 Pro10-1365
OSX.11.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
thanks 1 user thanked rockyroad_us for this useful post.
AndreasH
#15 Posted : Wednesday, January 03, 2018 12:09:24 PM(UTC)
AndreasH
Thank you all for your great tips.
I got it now with the tip from digitalphaser, thats exactly the best result for me.
There are a lot of functions left, that I have to learn.
greetings from germany
Andy
