Perttu
#1 Posted : Wednesday, January 03, 2018 3:37:51 AM(UTC)
Perttu
Hi I am about to purchase viacad or sharkcad. If I have understand viacad dont generate 3d curves as curves
to 2d views, but uses instean polilines. ( shark does use curves? )
Can anyone show an examble how accurate the polyline generated "curves" are?
Perttu
#2 Posted : Wednesday, January 03, 2018 7:16:20 AM(UTC)
Was thanked: 78 time(s) in 75 post(s)
Hello Perttu
Yes that is accurate statement, SharkCad can generate precise curves in the 3d to 2d tools-line views. ViaCAD's 3d to 2d tools generate polyline views. These are accurate fitted polylines its not just a representation of the geometry its a fully accurate polyline so the geometry is fully accurate. The difference is you have a polyline vs a curve if you are using the geometry for drawings or documentation there is no difference.
I have attached a dxf that you can review. You can also download a trial version of the software for review.
1H333012b.dxf (365kb) downloaded 4 time(s).
1H333012b.dwg (38kb) downloaded 4 time(s).
Windows 10, Win 7
murray
#3 Posted : Wednesday, January 03, 2018 7:34:06 AM(UTC)
murray
Was thanked: 56 time(s) in 46 post(s)
Accuracy is relative to local curvature, not absolute. The picture shows point density of a half-scale polyline from sheet view vs. the original curve.
Edited by user Wednesday, January 03, 2018 7:36:11 AM(UTC)  | Reason: Not specified
Polyline point density vs original curve.PNG (35kb) downloaded 5 time(s).
Perttu
#4 Posted : Wednesday, January 03, 2018 11:26:23 PM(UTC)
Perttu
Looks "fair" enough to me
Perttu
