This is the file error I get.(below) SharkCad Pro 10.0.3 Build 1356 Mac OS 10.13.2 I cannot use any of the older Sharks because I upgraded to High Sierra; wondering if that was a mistake. Thanks, Art
Translator Name : Spatial InterOp Connect ( Version : 2017 1.0.0) System Name : Darwin Machine Name : Arthurs-Mac-Pro.local User Name : arthurcarr Source System : STEP Destination System : ACIS Input File : /Users/arthurcarr/Downloads/91251A106_BLACK-OXIDE ALLOY STEEL SOCKET HEAD CAP SCREW.STEP Output File : test.sab Start Time : Tue Dec 26 20:32:08 2017 Message : === Translation Options === Message : TranslateSheetBodies : 1 Message : TranslateLayersAndFilters : 1 Message : TranslateAllClass2SheetsInSingleBody : 1 Message : TranslateAttributes : 1 Message : TranslateFreeCurves : 1 Message : Healing : 1 Message : TranslateFreeSurfaces : 1 Message : EnableWideCharacter : 0 Message : =========================== -------------------------Source File Header Information------------------------- Modification Date : 2013-10-30T21:15:46 File Name : 91251A106.step Author : '' Organization : '' Source System : SolidWorks 2010 SwSTEP 2.0 Version : AP203 Authorization : File Description : 'STEP AP203' Implementation Level : 1 File Schema Name : 'CONFIG_CONTROL_DESIGN' Document Type : Part Units : INCH Format Type : STEP -------------------------------------------------------------------------------- Source Document Preprocessing Result : Success -------------------------------------------------------------------------------- Target Document Preprocessing Result : Success -------------------------------------------------------------------------------- Start BRep -------------------------------------------------------------------------------- BRep Source Representation Preprocessing Result : Success -------------------------------------------------------------------------------- BRep Source Representation Postprocessing Result : Success -------------------------------------------------------------------------------- BRep Target Representation Postprocessing Result : Success -------------------------------------------------------------------------------- End BRep ------------------------Representation Conversion Summary----------------------- No. of Acorn Bodies : 0 No. of Mixed Bodies : 0 No. of Solid Bodies : 1 No. of Wire Bodies : 0 No. of Free Surfaces : 0 No. of Free Curves : 0 No. of Sheet Bodies : 0 No. of Free Points : 0 BRep Conversion Result : Success -------------------------------------------------------------------------------- Start DocumentFeature -------------------------------------------------------------------------------- DocumentFeature Source Representation Preprocessing Result : Success -------------------------------------------------------------------------------- DocumentFeature Source Representation Postprocessing Result : Success -------------------------------------------------------------------------------- DocumentFeature Target Representation Postprocessing Result : Success -------------------------------------------------------------------------------- End DocumentFeature ------------------------Representation Conversion Summary----------------------- No. of Selection Sets : 0 No. of Working Coordinate Systems : 0 No. of Associative Groups : 0 No. of Layer Filters : 0 DocumentFeature Conversion Result : No Entity to Translate -------------------------------------------------------------------------------- Start Assembly -------------------------------------------------------------------------------- Assembly Source Representation Preprocessing Result : Success -------------------------------------------------------------------------------- Assembly Source Representation Postprocessing Result : Success -------------------------------------------------------------------------------- Assembly Target Representation Postprocessing Result : Success -------------------------------------------------------------------------------- End Assembly Assembly Conversion Result : No Entity to Translate -------------------------------------------------------------------------------- Target Document Postprocessing Result : Success -------------------------------------------------------------------------------- Target Document Postprocessing Result : Success -------------------------------------------------------------------------------- ---------------------------Document Conversion Summary-------------------------- No. of Items of DocumentFeature Representation : 0 No. of Items of BRep Representation : 1 Message : Setting save mode for ACIS file based on the file extension Output File "test.sab" Writing has Failed with code 16777217 Error : Target document not saved. Finish Time : Tue Dec 26 20:32:08 2017 Translation Result : File Save Error --------------------------------------------------------------------------------
Hi Art I also have problems with STEP - but exporting in my case causes issues I work around this by using another APP called FreeCAD as a STEP stepping stone I can recommend this ! Jol
Hello Art Can you post one of the files you are trying to import. They look like components from mcmmaster Carr? If you draw a small sample file in shark and export to step and then import does it come in ok? Regards Jason
Art You can also download the .sat file instead of step from mcmaster Carr till the step gets sorted out. Regards Jason
Wow, thanks guys!! Appreciate the hint about the Mcmaster files, I forgot other formats were available. Unfortunately I needed to import some Keystone parts as well. I will check there too. And yes, if you export a file out, and try to re-import, you get the same error. Art
Is this going to be repaired?
Pretty basic problem.
Art
Edited by user Tuesday, January 9, 2018 8:51:38 AM(UTC)
Hello? Do I have some freakish problem or is nobody importing files? I get meshes when I import DXF, errors with step and iges (and no parts). the only thing I can import is SAT. Do I have to call to get an answer? If I have a computer problem I apologize in advance, but I am getting stuck here and cannot import step or iges. I have many component parts to import and am dead in the water. Mad Art Sharkcad Pro 10.0.3 1356 OS 10.13.2
Art - have you tried to use FreeCAD as a stepping stone I know it's not ideal - but - It gets me out of all sorts of issues with Step files not writing correctly from Shark (... such that my client on NX / Alias can't read them) Jol
Thanks: 46 times Was thanked: 299 time(s) in 204 post(s)
I exported a dxf yesterday for my work after flattening a mesh. The dxf has very little export options, and consequently Catia couldn't read the files. Turns out it was exporting exverything in a 3d format, as I tried exporting a square, 4 lines, and that worked fine. Would be nice to have more options like export curves only etc. I then worked around it in NX and brought in both stp and igs in ViaCAD V10 Pro, windows 7. Everything worked fine. I've had some very freakish behaviour from mine recently. The graphics went crazy on one of my parts and it went see theough and whilst rotating flickered on and off all the time. The part ended up totally corrupt and i had to start again......
Art
Looks like build 1354 works as expected, do you have the older build of v10 to revert to? If not contact tech support for help
http://support.encore.co...1307&product_id=3912 Regards
Thanks Everybody, I will contact support. I had to go to 1356 because of some other dramatic problems after I updated to High Sierra. Art
The step import issue has indeed been addressed in the last English WIP build 1359.
Feel free to contact me through our support site with a request for the new build (proof of purchase will be required)
You can use the link below to access the request form.
http://support.encore.co...frm.aspx?product_id=3912 Edited by user Friday, January 12, 2018 2:22:37 PM(UTC)
Todd Q CAD Support Specialist Encore Software/ IMSI Design
