#1 Posted : Saturday, December 23, 2017 3:27:27 PM(UTC)
Hi All,
I'm looking for some help on scaling my centrelines by default. When I start a drawing, I click centre line, click the circle in pops a centreline. The axis over hang is always at 10, I don't like it so big but can't find a way to change the default.
Also when I put a centre line in a section view for example, even when showing as a 'centreline' you wouldn't know as it shows a solid line! I have to go into the inspector, pen properties, pattern ( pull down tab) then click 'more'. Then we get a pop up box which gives us another scale. Reduce this down and it looks like a centreline! I'm after changing this by default as well.
Thanks in advance.
#2 Posted : Wednesday, January 10, 2018 2:07:25 PM(UTC)
Hello
These are not currently able to be set to a user value by default.
You can access the pen pattern an weight dialog faster by right clicking on the object.
