Thanks: 31 times Was thanked: 27 time(s) in 12 post(s)
Greetings all,
I am a recent new user to SharkCAD and this is my first post to this forum. Forgive any breach in protocol but I will learn quickly.
I am having an issue with a drawing. I have created a Model to Sheet drawing. The four basic views are fine and present in 3rd angle projection. However, upon cutting a section view it unfolds in 1st angle projection. I cannot find how to make all the views project correctly nor can I find a way to flip the section cutting arrows.
Edited by user Friday, December 15, 2017 8:51:06 PM(UTC)
(319kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 181 times Was thanked: 159 time(s) in 109 post(s)
Welcome to the Forum, Model-To-Sheet [MTS] is not always perfect.
Sometimes you will have to modify views and dimensions.
I think 'Deep Select' will allow editing the arrows, didn't try it
though.
(48kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Hello
To flip the section view you click on draw view to activate then select the section arrow and go to inspector and check the flip option.
(29kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked jdi000 for this useful post.
