Andrew Gray
#1 Posted : Wednesday, December 13, 2017 3:51:00 PM(UTC)
Andrew Gray
HI all
I have a question about custom toolbars
I would like to make one for view eg Top, Front...etc
Is this possible?
Andrew
Jolyon
#2 Posted : Thursday, December 14, 2017 4:45:24 AM(UTC)
Jolyon
I don't think so
Navigator has a pull-down for views - that's what I use
L. Banasky
#3 Posted : Thursday, December 14, 2017 9:22:35 AM(UTC)
L. Banasky
I've been using the 'Shortcut Manager' assigning a key .
Andrew Gray
#4 Posted : Thursday, December 14, 2017 2:42:54 PM(UTC)
Andrew Gray
Thanks again all
Andrew Gray
#5 Posted : Monday, December 18, 2017 9:57:00 PM(UTC)
Andrew Gray
Hi all
Shortcuts are good but are case sensitive
eg Top view = t (lowercase) but T (uppercase) will not work
Andrew
Andrew Gray
#6 Posted : Tuesday, December 26, 2017 4:02:05 PM(UTC)
Andrew Gray
Hi all
I just wanted to float this back on top
Andrew
L. Banasky
#7 Posted : Wednesday, December 27, 2017 6:13:51 AM(UTC)
L. Banasky
Hi Andrew,
It works on Windows, did you select 'Assign Key' after you
entered 'T'?
Forgot to add 'Remove Key" first.
I use 'u' for Top, 'd' for Bottom 'r' for Right, 'l' for Left
't' for Front, 'a' for Back, 'f' for Isometric.
Edited by user Wednesday, December 27, 2017 7:10:28 AM(UTC)  | Reason: Not specified
Assign Key.jpg (62kb) downloaded 7 time(s).
Remove Key.jpg (57kb) downloaded 6 time(s).
Andrew Gray
#8 Posted : Wednesday, December 27, 2017 3:12:56 PM(UTC)
Andrew Gray
Thanks for the reply, what I want is the shortcuts to work with either lower or upper case
can two letters be assigned to one shortcut?
Andrew
#9 Posted : Wednesday, December 27, 2017 3:36:07 PM(UTC)
Hello Andrew
Shortcuts currently work with a single key value.
Andrew Gray
#10 Posted : Wednesday, December 27, 2017 5:30:58 PM(UTC)
Andrew Gray
Because I'm using viacad for mechanical design I have set all the shortcuts to uppercase
