HI all I have a question about custom toolbars I would like to make one for view eg Top, Front...etc Is this possible? Andrew
I don't think so Navigator has a pull-down for views - that's what I use
Thanks: 176 times Was thanked: 158 time(s) in 108 post(s)
I've been using the 'Shortcut Manager' assigning a key . Larry
Hi all Shortcuts are good but are case sensitive eg Top view = t (lowercase) but T (uppercase) will not work Andrew
Hi all I just wanted to float this back on top Shortcuts are good but are case sensitive eg Top view = t (lowercase) but T (uppercase) will not work Andrew
Hi Andrew,
It works on Windows, did you select 'Assign Key' after you
entered 'T'?
Forgot to add 'Remove Key" first.
I use 'u' for Top, 'd' for Bottom 'r' for Right, 'l' for Left
't' for Front, 'a' for Back, 'f' for Isometric.
Edited by user Wednesday, December 27, 2017 7:10:28 AM(UTC)
(57kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks for the reply, what I want is the shortcuts to work with either lower or upper case can two letters be assigned to one shortcut? Andrew
Hello Andrew Shortcuts currently work with a single key value. Regards Jason
Because I'm using viacad for mechanical design I have set all the shortcuts to uppercase
