SharkCAD Pro V10 and Animation
I'm attempting to test the animation capability of Pro V10. It is asking to install quicktime libraries from Quicktime.com. But as we know, Quicktime is no longer supported by Apple. Where do I get the necessary libraries and are they compatible with Windows 10? This could render Shark useless for a significant part of my work.
Thanks: 262 times Was thanked: 130 time(s) in 100 post(s)
ok great. Then how do I get it to work without quicktime? It keeps telling me to install quicktime. I'm on V10 build 1335. When I check current version the webpage says I have the latest.
Ok thank you. Downloading now. Assume I can use the same credentials for the upgrade?
It's no longer asking for the quicktime libraries, but animation tools do not work. Even tried creating an automated movie with defaults and the system simply hung. i'm thinking this upgrade from V9 2D/3D isn't going to work for me.
