Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
They're back!
I'm sure they are on the wrong forum.
(61kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 60 times Was thanked: 46 time(s) in 32 post(s)
It's unavoidable. Usually it is the duty of the moderator to clean up the forum. I suspect that the owners of the forum are not able to review the forum daily. This forum is not big. I do not think it would be a lot of work.
Agree Surely this duty can be devolved to one of the most active users ! It's sad to see it like this
1 user thanked Jolyon for this useful post.
Originally Posted by: digitalphaser It's unavoidable. Usually it is the duty of the moderator to clean up the forum. I suspect that the owners of the forum are not able to review the forum daily. This forum is not big. I do not think it would be a lot of work.
More likely to be a time zone issue....
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
Originally Posted by: BillB More likely to be a time zone issue....
In this case, I do not see any problems. The forum is small. Sometimes during the week there are no new posts. If the administrator is once a day to remove junk and ban spammers, then this will be enough for now. I think.
Again. Forum is an important component of promotion. Nice and lively forum is a sign of a successful and developing software.
Below is the screenshot of the punchsoftware forum. It does not look convincing. I would not spend money for such software. It was an example. ;)
(82kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked digitalphaser for this useful post.
